1 members (Hotrod Lincoln), 60 guests, and 0 robots.
Topics128,050
Posts1,055,641
#660454 07/07/2010 8:17 PM
I've sanded and primered my 65. It has already started to rust, as I live near the Ocean. Is there a rattle can primer that won't rust or do I need to paint it?
not in rattle cans, but epoxy primer is what you need - could also use something like Zero Rust, which is good protection, can be sanded later and considered as a sealer prime coat
I read Epoxy is good, thanks for the info. I don't have a compressor or spray gun, anyway Thank you Brett
any paint can be applied with a brush or roller [and get better coverage than rattle cans], just have to work fast and settle for some imperfections, but if you're trying to protect the metal work as you go along until it's all ready for professional painting, brush on some Zero Rust or such, working fine for something that won't fit any spray booth I can afford!
One thing to consider as well with a primered vehicle, primer is porous and will allow moisture to get to the metal surfaces below it. I have seen surface rust form under primer before. You can't really drive around in primer for long and hope to avoid the rust problem. Paint it if you can, sooner the better.
Hank
1951 restoration on website
http://www.hanklong.com
wow nice Bus. Hank that is what I'm thinking except I havent worked this year. Trying to get a buddy to shoot it. I just would rather do it right the first time, hoping I could find something inexspensive. thanks Brett
epoxy primer, properly applied, is not porous
Eastwoods Epoxy primers are'nt for sale in California any ideas, besides having shipped to a friend in another state.
You're not done with that thing yet? Stop goofing off and get that bus on the road, I want to go for a ride grin
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Don't you have an auto paint store near you? If so just ask them what they recommend.
Woody
Door Art Collection
Another thing to consider is to just clear over the top of the primer. Seen some sweet rides with a little pin striping over the primer and just clear the whole thing.
Hank
Thanks Woody, I start a new job monday so I'll look into it after work. Brett
