4 members (baldeagle, walter74, BillCollins, Cosmo), 87 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#659972 07/06/2010 1:35 AM
I recently installed a new speedometer cable with a plastic male part that enters the speedometer in my '53 3600. After a few hundred miles, the speedometer quit working. I inspected both ends of the cable and found that the transmission end is square steel and looks like new but the speedometer end is plastic and appears to have rounded off to a point. Should the proper cable have steel on both ends? Any other ideas?
"It wasn't broke but I still decided to fix it. Now its broke"
I really love my coon hounds
Pics at http://s982.photobucket.com/albums/...0truck/53%20Chevy%20truck%20Sept%202010/
You will probably find that most of the replacement cables have a plastic tip. It should work fine as long as the spedometer is working properly. If the spedometer is binding up it will brake the tip off of the cable. Usually you have to remove the spedo and dissassemble it to clean and lube it properly. You could try a little WD40 on the gears and maybe get lucky.
Fred
