8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, msmall), 122 guests, and 4 robots.
Topics128,065
Posts1,055,863
Members48,428
#659730 07/04/2010 10:38 PM
1 Offline
I am in the process of puttin the ol boy back together and will be installing gauges , wiring, choke throttle etc. As I look at the firewall, I see 30 or so holes of various sizes and shapes. Is there a diagram somewhere that shows what goes through what hole? It's on a '51 1/2 ton. Thanks
If you can get a look at an assembly manual,it'll show what goes where. Try searching http://chevy.oldcarmanualproject.com/
Drew
DrewP #659901 07/05/2010 6:06 PM
if you can't find the assembly manual, look thru the shop manual, there's likely a few pics in there to guide you .... most things go where you'd expect, the shortest route .... another guide is the firewall grommet kits from the vendors, usually there's only a half dozen needed and one of them carries multiple items, but with 30, a fair number of yours will be non-original holes that'll need to be plugged wink
squeeze #660625 07/08/2010 4:14 AM
A bunch of these are where the retainer clips for the inside firewall cover attach. Maybe 8-10, I can't remember.
