8 members (TUTS 59, wilbur53, Joe H, tclederman, Charles in CA, kades51, 2 invisible),
74
7
Mod | | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 29 | I have a '49 Chevrolet Pickup. At least that is what it is titled.
Very little of the paint is left but it looks like Mist Green that is listed in some '50 GM car color samples. I have checked out the Auto Color Library and don't see anything close, Puts me in mind of a Seafoam Green.
Not sure how to post pics or I would. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Are you sure it's the original color? If you're not sure you should clean off a spot on the firewall, it's the least likely place to be repainted. The colors for cars and trucks are not the same and truck colors are pretty distinct. Look HERE and you'll probably find your color match. | | | | | Joined: Dec 2006 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 29 | Are you sure it's the original color? If you're not sure you should clean off a spot on the firewall, it's the least likely place to be repainted. The colors for cars and trucks are not the same and truck colors are pretty distinct. Look HERE and you'll probably find your color match. I do think it is an original color as I found a replacement grille at a swap meet that was an exact match. I have checked out the Aoto Color Library and there doesn't seem to be a match. It is difficult to judge because of the computer but none of the colors seem to be close. I have found some '48 automobile colors that are close or maybe a match but no truck colors. Again it looks like a sea foam green.
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Not sure if it was available in '48 but Seacrest Green is a medium green and was available in '51 (my year) for sure.
But, if your color is not on that chart than it was either repainted or delivered from the factory with a custom paint color, in which case all bets are off.
| | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I was just thinking since there were no body plates indicating color and trim on them old trucks, right?
One should be able to paint it any stock color offered that year and it would be correct, right?
How would anyone dispute it being the original color if no trace of any color can be found and you painted it with an original color?
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | | | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | Look behind either the cowl vent or the driver's side vent. On my 1 ton it was the one place that had nice unfaded factory paint. Also uder the window seals but if you aren't replacing the windows.... Get a photo account at Flickr.com (my preference) or pbase which woody uses and then post a link. | | | | | Joined: Jun 2010 Posts: 5 New Guy | | New Guy Joined: Jun 2010 Posts: 5 | Hey friend you can visit the website "http://www.autocolorlibrary.com" for complete information. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Seacrest Green was a (the) medium green available from 47-52 on regular-cab trucks. | | |
