0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | just wondering what psi that everyone is using have mine set a 10 should i raise it or go the other way. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | way too much, stuff is too spendy to waste, 3 or 4 should get'er done
Bill | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The gas settings are cubic feet per hour, not PSI. And it depends on if you are using straight CO2 or mix and the material you are welding and the wire. The more argon, the more gas you need. We start out at about 25 and go from there. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | How much does wind affect welding outside. Do you just not weld in the wind, or do you try and compensate?
I know this depends on hard the wind is blowing, are there any guidelines.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | wind affects it lots, hard to maintain a consistant 'bubble' of gas shrouding at the weld point if it's windy, only 'compensation' is go inside or pick another day and re what Cren sez vs my numbers - I forgot the gauges in Canada are different, litres/minute  Bill | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | thanks for the info, use it in the barn so wind is not much of a problem, using the mix. just wondering what the rest of you were setting the the gauge at, seems to work ok at 10, may try to jump it up and see what happens then try the lower setting, thanks again | | | | | Joined: Nov 2004 Posts: 2,409 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,409 | The manual for my Miller 180 requires setting the regulator at 20.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | I set it at 25 psi in my mig and indoors.
Ganesh | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | moved it up to 20, seams to work a little better, thanks again for the input | | | | | Joined: Oct 2010 Posts: 21 New Guy | | New Guy Joined: Oct 2010 Posts: 21 | If you need to mig weld outside, learn to cup the welding tip with the other hand. I use a heat shield in the palm of my hand to block the wind. You can block the wind with a sheet of plywoood. The wind will put holes in your weld.
1940 Chevy 1 1/2 ton, 1959 Chevy 1/2 ton, 1966 Chevy C20.
I can explain it to you but I can't help you understand it.
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | My gas salesman made a funny statement when I asked him what I should set my gas pressure setting at...He said I sell gas so set it high, but you are buying the gas, so set it at the optimum level, to render the best weld, in the environment and conditions you are welding in. | | |
