7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 9 New Guy | | New Guy Joined: Nov 2009 Posts: 9 | I have a '62 235 in a C20 that is missing the distributor. I got a distributor and now would like to install it but have never removed or installed a distributor before. Can someone direct me to where I can get some installation instructions so I make sure I drop it in corretly and can get the timing correct? The motor turns over easily with the plugs out and I want to see if I can get it to fire/run. If anyone can help I'd appreciate it. I also need help with where the wires from the distributor need to go. A book, a post, pictures, whatever instructions will be helpful.
"Gas money give out in Gurnee" Eddie from Christmas Vacation
1962 C20, currently "Yard Art", working to reverse that.
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Do a search under "install the distributor" and you'll have lots of info on this. Use the " " marks for your search. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | The best thing to do is get a sevice manual for Your truck it will help not only with the distributor but alot of things on your truck.
1st- get engine on TDC - take off the valve cover and turn engine over in the right direction and watch the intake valve 2nd from front as it starts to close look for the timming mark on the flywheel when you see the triangle line up with the pointer that is on the bell housing you're at TDC on no.1 cly.
2nd- take your distributor and set the rotor at the 2 oclock position when looking at from the side .12 oclock would be pointed at the motor at the same time the housing needs to be turned so that the mounting bolt is lined up with the hole
3rd- under the dis. is the oil pump if you look at the bottom of the dis shaft you'll see what looks like a big screw driver blade and if you take a flashlite and look in the dis. hole you'll see the pump has the female part that it fits into you will have to take a screw driver and turn that until it lines up with the dis. at the 2 oclock position
4th- take the dis. and put it in there you might have to move the oil pump around one way or the other until it lines up .install the mounting bolt .the rotor(dis) is now pointed at the no.1 plug on the dis. cap and should be close
5th- install the dis cap and wires in the firing order
If memory serves me its 1,5,3,6,2,4
Pete
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't want to confuse things but I believe the conventional positioning is for #1 on the cap to point straight out away from the block towards the fender. In Pete's52 description that would be 6 o'clock. This has nothing to do with the motor running right, it just looks factory correct. | | | | | Joined: Mar 2010 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 112 | Piece of cake, Scott. You only need to learn some basics which apply to almost all four stroke engines.
Your firing order is 1-5-3-6-2-4 Number one cylinder is the front most, up by the water pump. Your engine rotates clockwise. Your distributor rotates clockwise.
Begin by preparing your engine to accept your distributor. Make sure your key is off and nobody to punch your starter. Remove your spark plugs, take off your valve cover. Look at your valves for your number one cylinder. Exhaust valve is above your exhaust port, intake above your intake port.
Now the work. Slip your truck into high gear, brake off. You do the pushing and pulling, have your wife watch those valve rocker arms. Grab a tire or bumper, make your engine turn over. Watch for the exhaust valve to go down, then come back up. Watch the intake valve go down and when the valve begins coming back up, slow down, rotate the engine until the intake valve stops going up, right when the valve stops moving. You are now very close to Top Dead Center (TDC) on your number one cylinder.
Have your wife shine a flashlight down at the timing hole in your bellhousing. Very slowly rotate your engine clockwise and have her watch for a "silver ball" fly by through that hole. Rotate your engine forwards and backward, just a little, until you can just about center that silver ball in the hole. Sometimes, with a loose engine and a tight fan belt, you can grab a fan blade near the pulley and rotate your engine by hand, with the trans in neutral. Your valves must NOT move during this, if so, you rotated too far, go back and start over.
Get that silver ball on the flywheel lined up in the bellhousing timing hole. You are now close enough to install your distributor. This will not be perfect timing but close enough to fire up your engine then time with a timing light.
Prep your distributor. Used points, set a .016 gap, new points set a .019 gap. Usual rules apply, all is clean, your point lever is dead center on a high distributor cam lobe.
Shine a light down your engine distributor hole. Note how your oil pump shaft is aligned. Hold your distributor down by your engine and rotate until the vacuum advance will well clear your block, you need room to turn your distributor for timing without anything interfering. Now slowly rotate your rotor on your distributor until your distributor shaft end roughly aligns with your oil pump shaft. You can turn the oil pump with a long screwdriver if needed.
Carefully slide your distributor down into the hole, wiggle the rotor a bit to engage your oil pump shaft. Might have to remove and install your distributor several times to get a proper alignment between your distributor shaft and oil pump shaft. Your rotor will turn a bit when your distributor gear engages your camshaft, might not align with your oil pump shaft. This is a trial and error job. When all is aligned, your distributor will easily bottom out against your block.
Fetch your distributor cap and properly fit it to your distributor, only goes on one way. Take the cap back off then study where the rotor will be pointing with the cap on. The spark plug wire fitting which your rotor most closely points to will be your number one cylinder spark plug. Have to be careful, have to study close to be sure you have the right spark plug wire fitting. Mark this one somehow, piece of tape, whatever.
Install your distributor hold down clamp and bolt, only finger snug, not tight, snug.
Grab a thin strip of paper, like printer paper. Slowly rotate your distributor until your points open. Slip in your thin paper. Rotate your distributor a little until the points close and seize your paper. Grab your paper strip and tug just a little, slowly and carefully rotate your distributor clockwise until your points just let go of your paper. The moment your paper slips out, stop. Your timing is now rough and close enough to fire off your engine, at least get a backfire.
Tightened up your distributor clamp.
Double check your work. Silver ball on your flywheel just about center in your bellhousing timing hole. Both number one cylinder valves are closed and your number one piston is close to TDC. Your points are just opening and your rotor points very close to a spark plug fitting, the one you marked with tape.
Put everything back together, valve cover, distributor condenser, distributor cap, spark plugs and all that. Make sure all parts are in place and everything is a go.
Your number one spark plug goes in the distributor hole you marked. Looking down at your distributor, moving clockwise, your number 5 spark plug wire next. Continuing clockwise, number 3, then number 6, then number 2 and finally, number 4 spark plug wire. You should see a spark plug wire cylinder order:
1 5 3 6 2 4
Number one in the hole you marked.
Using a squirt gun, fill your carburetor float bowl with 1/4 cup of gas by carefully squirting gas down into the vent tube which is top and center of throat on your carb. Comes out at an angle, vent hole points upward. No more than 1/4 cup. Two squirts down your carburetor throat, adjust your manual choke half on.
Now you are ready to set your engine on fire, maybe even your truck. Keep a thick towel handy to toss over your carburetor should it catch on fire. Smother the fire, never spray with water.
If you have all right, this will not happen. Your engine, in time, should sputter and cough then eventually catch and run. If you luck out and your engine fires up, let the engine run at a fast idle, your choke should do this, a fast idle for about two minutes. Check your oil pressure to be sure you have some!
Your timing will be off, this is expected. Once warmed up, you can time your engine with a timing light. Idle down to about 400 to 500 rpm. Clamp your vacuum hose on your vacuum advance; bobby pin from your girl, clothespin, clamp, whatever, just pinch the hose so no vacuum to your distributor. Timing lead to your number one spark plug wire, other wires you know where those go. Slightly loosen your distributor clamp, snug, not loose, point your timing light at the timing hole in your bellhousing. Carefully rotate your distributor clockwise and counterclockwise until that silver ball becomes just about dead center in your bellhousing timing hole. This is good enough for now.
Scott, I am making a presumption you know all the things you need to do before test firing an engine, during running and after shutting down. Oil check, radiator water check, fuel line check, all those things you need to do for safety and to have your engine run.
I have given you a very basic method of installing your distributor. You only need to move along step-by-step very carefully. Mess up a step, your engine will not run or will not run right. Backfiring is a clue something ain't right.
You must have each step right or this will not work. You are to work slowly and carefully.
Now, before you try any of this, you are to go over to Google, then search like crazy and read like crazy on how to install a distributor and how to set the timing. You are to have all of this well in mind, know exactly what to do before you even pick up a wrench. Rehearse this in your mind and on your work bench. Do all of this, then check your work by doing this again. Lot of work turning over an engine, having everything lined up, worth doing two or three times before firing an engine to be sure you have all correct. No greater glory than having your engine fire up the first time you try.
There is a ton of information out on the web just waiting for you. Get out there then read and research, you will be rewarded.
Billyray
1948 GMC 3 Ton Flatbed 1952 Chevy 1/2 Ton Panel 1956 Chevy 3/4 Ton NAPCO
| | | | | Joined: Nov 2009 Posts: 9 New Guy | | New Guy Joined: Nov 2009 Posts: 9 | Thanks, This is a good start help getting "Yard Art"s name changed.
| | | | | Joined: Aug 2009 Posts: 35 New Guy | | New Guy Joined: Aug 2009 Posts: 35 | I just wanted to give a big thank you to the responders of this thread, this thing has been a life (and sanity) saver for me this weekend. I spent 6+ hours yesterday trying to get it all set right with no luck, I found this thread and this morning the truck was singing in less than an hour! | | | | | Joined: Aug 2009 Posts: 35 New Guy | | New Guy Joined: Aug 2009 Posts: 35 | I think I spoke too soon ^. It ran for a little while then I went to make some minor adjustments and now I can't even get it to start. I went by the instructions from billyray above for a second time to see if I could get it to run again but no luck. Now the best I can get is a single big backfire when I start it (after about 3-5 seconds of cranking. Any thoughts? A neighbor thinks my timing chain is so loose it's screwing it up but the truck did run (albeit roughly) before all this so I'm not so confident in that assessment.
Thanks! | | |
