13 members (Bill Hanlon, Oldcaliforniakid, Southerntruck, D B Cooper, Peggy M, Jims46, DadsFirstPickup, Ponchogl, Hotrod Lincoln, 32Fordpuchoptop, 2-Ton, 2 invisible), 81 guests, and 1 robot.
Topics128,049
Posts1,055,674
#657787 06/27/2010 6:39 PM
I'm trying to change my 65 over to the fully synchronized 3 speed saginaw that was used from 66. I have a 69 transmission I'm wandering if the shift arms on the side cover are correct. Could anyone send a picture of shift arms on a 66?
If you are still wanting to use the Shifter on the Column, it will probably be a challange. The Side Covers are pretty much different from each other. Unless someone one on here can jump in with a good way to tackle it, you may just want to go with a Floor Shifter. By the way, you'll also need to shorten the Driveshaft.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Riding in the Passing Lane
I have a 68 3 speed trans. that was in a 58 when I got it. It was hooked up to the 58 linkage. I can gat a photo of it tomorrow. George
1972 Chevy c10 Cheyenne Super
The tansmissions are the same length the only differance is the slip yoak and I have both.I have done some research I found that the saginaw used was pretty much the same from 66-87,and basically no change from 66-76. I was hoping someone knows for sure what was on the 66. I think my arms are off a 74,had to buy another transmission. The shifter arms were missing,so I,m trying to use what I have. Does anyone have some off a 66 for sale?
The original 3-Speed trans in a '65 is a Short Shaft trans (Tail Shaft). Correct me if I'm wrong that the newer 3-Speed Synchro trans is not a Short Shaft trans.
GMC 9500 Fan
Detroit Diesel Fan
If you send me an e-mail address I'll send you a photo of the one I have. [email protected]
The older style has less transmission and more tailshaft. I have had them side by side they both measure 28 1/2 end to end.
Still need pics of 66 shifter arms? I could take a few shots this weekend if you do.
Many years ago, I swapped in a later 3spd Muncie(?) trans into the 63 I had then. As I remember, the lower end of the later arms were grafted to the upper ends of the early arms and then with some tweaking to fit better, it worked, but not well.
It seems there was some flex or poor angles that gave it a less than positive feel. A local trans shop did the work for me, and I never tried to improve on it before selling the truck.
