9 members (VicZ, Ridgeback, RAC1812, Shaffer's1950, Gdads51, artinva, klhansen, Otto Skorzeny, 1 invisible), 122 guests, and 1 robot.
Topics128,077
Posts1,055,928
Members48,430
#65911 09/17/2006 7:38 PM
I have a 1951 3/4 ton with 8 lugs that has the 4:10/1 gear ratio (I think) it is.
I also have a 1956 1/2 ton rear axle and front spindles.
Now the Questions, ..
1) What is the gear ratio in the 1956 axle?
2) Can I unbolt and replace the axle with the other without a major operation, and will the front spindles swap out the same?
I am sure someone out there has either done something simular, or given it a try.
Thanks in advance.
Collecting is fun, as long as momma enjoys riding in them.
#65912 09/18/2006 9:21 PM
The standard gear ratio for a 1/2 ton in 56 was 3:90 to one. That ratio was fairly standard from 55 through 59. If it came with an overdrive it probably had a 4:10.
#65913 09/18/2006 10:40 PM
I think your 3/4 ton would be 4.56 stock.
Paint & Body Shop moderator
#65914 09/20/2006 12:09 AM
The 1956 rear from a 1/2 ton truck would be either a 390 or a 410.The 390 came with the 3 speed manual and the 410 with a 4 speed manual.
#65915 09/20/2006 8:06 PM
Well is it worth the effort to change it to the newer rear end and can the front spindles be changed to match, or is it even worth atempting?
#65916 09/20/2006 8:07 PM
I do ,intend to change to a t-5 or a 700R tranny.
#65917 09/23/2006 5:09 PM
Old CT Guy,
I recently installed a T5 (.72 OD) in front of a 4.10. I've only had it on the freeway once-I'm working on tightening up the steering now- but the combination seems good. I'm guessing that 2,000 rpm gets me to about 70 mph, which is as fast as I need to go in this truck.
My original differential was a 4.57, and changing to the 4.10 made quite a difference.
