9 members (carbking, Mike B, klhansen, Youngin' Tut 59, Pete1946, Gray_Ghost, BarryP, dt235sd, 1 invisible),
89
Mod | | | Forums66 Topics128,139 Posts1,056,758 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 6 New Guy | | New Guy Joined: Jun 2010 Posts: 6 | can anyone tell me if the part number for a fender belongs to a 1/2 or a 1 ton truck 3682056
thanks
NEED AN ANSWER ASAP, thanks so much for your help | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Right hand 1 and 1 1/2 ton. 39 to 47. | | | | | Joined: Jun 2010 Posts: 6 New Guy | | New Guy Joined: Jun 2010 Posts: 6 | thanks,
are the two ton truck fenders different or the same.
are the 3 fenders whit different wheel opening on there?
part number 3682056 i was able to get some info off online that it has a 37-1/2" opening
whats the 1/2 ton and 2 ton and from where to where is the measurement?
| | | | | Joined: Jun 2010 Posts: 6 New Guy | | New Guy Joined: Jun 2010 Posts: 6 | which fender would you say this is half ton 1 ton or 2 ton? my truck | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I am looking at a GMC book. Fitment is 250CC,EC 280EC 300CC EC280 with 7.00x20 Front tires. These are 1 ton 1 1/4 ton and 1 1/2 ton. It appears that thee are 3 different wheel opening sizes for those years. It appears you have the middle sized one. I can't open the link. A Hollander book is really better in situations like this, but the oldest one I have is the 23rd edition that starts with the AD models. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Still can't open the link. CC & EC designated a conventional cab instead a cab over engine. Actually I need to correct myself, The coverage is 41 to 47 instead of 39 to 47.
| | | | | Joined: Jun 2010 Posts: 6 New Guy | | New Guy Joined: Jun 2010 Posts: 6 | sorry for all the problems with posting the image, try cut and copying this one.
http://www.kodakgallery.com/imaging-site/services/doc/4902:345671494506/jpeg/BG/async
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I was able to cut and paste the link. Because it is lowered and has non stock wheels, it is difficult to say what fenders you have. However, I'm quite sure the p/n you mentioned earlier would have a larger wheel opening than you have now. | | | | | Joined: Jun 2010 Posts: 6 New Guy | | New Guy Joined: Jun 2010 Posts: 6 | thanks, anyone out there know where i can get a good set of front fenders for a half ton truck?
