1 members (Hotrod Lincoln), 97 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#659051 07/02/2010 4:23 AM
On a '58 235, my pan has a very small hole (maybe 1/8 inch or smaller) located in the right front attachment flange. It appears to belong there, and is open to the inner part of the pan.
The engine is a new rebuild, and running well, but I notice that there is a very slight amount of oil escaping from that hole. I suspect that it is to assure that there is not excessive oil in the crankcase, but...I'm not sure. Can anyone shed a little light on my confusion?
There shouldn't be any open holes in the pan. Any holes should either have an attachment bolt or plug in it.
Bill Burmeister
Longbox55,
What you say is what I suspected, but the little hole is extremely neat and clean, and very much as if from the factory; a tiny little thing near the front most right pan bolt.
It doesn't make sense as there is the huge breath from the crankcase.
I will have to plug it.
Gary
