| | | Forums66 Topics128,098 Posts1,056,167 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65881 09/17/2006 2:42 AM | Joined: Dec 2005 Posts: 27 Junior Member | | Junior Member Joined: Dec 2005 Posts: 27 | I got a rear end from a swap meet and iam trying to figure out what i got. I sand blasted it today and these are the #s I found. K174 and GM4 and HA12 and 3856525 it is 62" from the outside of the drum to the outside of the drum. its a 12 bolt. and has 6 lug. I did a search but could not find any help. searched the net and found one sit that I found one of the #s. it was the GM4 # rpo# it was a 3.67 gear ratio. but it said this number was found in the drivers manual. so that is what Iam try to find the gear ratio. and what it came from? thanks for any help. | | |
#65882 09/17/2006 2:50 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You can count teeth to find the ratio, or turn the pinion and count the axle shafts at they turn together. Can't help other than that. I bet a picture would help someone id it for you. | | |
#65883 09/18/2006 1:43 AM | Joined: Jul 2006 Posts: 49 Member | | Member Joined: Jul 2006 Posts: 49 | divide the number of teeth on the ringgear with the number of teeth on the pinion to get the ratio.
64 c10 89 rs 62 econoline 50 ford coupe
#65884 09/18/2006 1:43 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Pull the cover and look at the ring gear. Somewhere along the edge you'll find a series of numbers. Two of those numbers are for the teeth on the ring and pinion gear.
My GM 12 bolt has the numbers "7 GM (six numbers) 11 41 s 02" stamped on it.
11 pinion teeth to 41 ring teeth means a 3.72 ratio.
Good luck!
#65885 09/19/2006 12:12 AM | Joined: Dec 2005 Posts: 27 Junior Member | | Junior Member Joined: Dec 2005 Posts: 27 | | | |
