| | | Forums66 Topics128,050 Posts1,055,673 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65851 09/16/2006 7:49 PM | Joined: Aug 2002 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 30 | I have two different intake manifolds, and I'm wondering if one is better than the other. I've measured all of the ports and the sizes are the same. Post spacing for the carb is identical, and I've verified that the carb will fit on both manifolds. The intakes are the same except for the "box" that the carb mounts to - one is about 2X taller than the other. Pictures here: http://www.sacred-cactus.com/g2/v/troy/61Chevy/intake/IMG_2581.JPG.html http://www.sacred-cactus.com/g2/v/troy/61Chevy/intake/IMG_2585.JPG.html The intake in the back that is rust-colored appears to have a smaller port in the center under the box, but it is an optical illusion. I measured everything with a dial caliper. The blue manifold is the one that has been on my truck since I bought it and the other is a spare that I've had. I am replacing a cracked exhaust manifold, and so I figured I'd ask while I'm at it. Thanks!
1961 Chevrolet K10
#65852 09/16/2006 10:08 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | troymckaskle,
My bet is that the taller one came off a older engine, and the shorter one a newer rig..more like your '61.
From a "Stroker McGurk" standpoint, the taller one might give you some additional 'ram' effect for the fuel/air mixture, but the length of your throttle linkage might dictate which one you actually use.
Stuart | | |
#65853 09/16/2006 11:50 PM | Joined: Aug 2002 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 30 | Thanks, I thought about it more and ended up putting the original one back on because gettings things together right with the manifolds is such a PITA, and I didn't want to get things buttoned back up and find out that I had issues. Much easier job with 2 people...
1961 Chevrolet K10
