0 members (), 109 guests, and 3 robots.
Topics128,062
Posts1,055,854
Members48,428
#658514 06/30/2010 5:43 AM
I am building a 54 chevy half ton pickup. I am building up a gmc 302 for it and want to use the original 235 chev. bell housing. I am told that I need a flywheel from a gmc 270 or 248. Is this correct and does anyone know where to get one or have the casting no. for one Thanks.
cw54 #658518 06/30/2010 6:00 AM
Partially correct.
Is your truck going to be 6 volts or 12? That makes a difference for the flywheel. The 302 has a 6 bolt flange. Only 1955 and possibly 1954 248 flywheels are 6 bolt 6 volt. The later 1956-1959 270 flywheels are 6 bolt 12 volts.
Look up James Larowe. I'm sure he has the flywheel you need.
my truck was a 12volt. So I guess I need the newer one. Thanks
cw54 #658658 06/30/2010 11:42 PM
Your truck may have come to you as a 12V but it came from the factory as a 6V. It's possible you still have a 6V starter. Count the teeth on your current flywheel. If it's 139 then you have a 6V starter. You'll need a 6V GMC flywheel to use it.
Cletis #658668 07/01/2010 12:21 AM
Or you might have to pony up for a 12 volt starter. Cletis is correct, you don't want to mix 6 volt starters with 12 volt flywheels.
