2 members (Hotrod Lincoln, baldeagle), 67 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#65844 09/16/2006 5:58 PM
Hello all, I just purchased a universal tranny mount for my 41 chev,the tranny mount fits into the end caps,the end caps mount to the frame. My question is... does the mount just float in the end caps or do I weld the mount to the end caps once the mounts in place? Thanks James
If it was easy, everybody would be doing it.
#65845 09/16/2006 7:45 PM
Weld it up. You don't want it moving at all once you start driving it!
#65846 09/16/2006 8:23 PM
Especially since it would do the left-to-right slide throwing your driveline out of alignment and causing quick failure of your trans and motor mounts.
