| | | Forums66 Topics128,087 Posts1,056,119 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 111 | Can anyone give me guidance on installing a fan shroud? 59 Apache
1959 CHevy Apache
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | from a 56, but if you're putting the aftermarket plastic shroud in with a small block, a picture might help ... needs to be so the fan is about half inside Bill | | | | | Joined: Apr 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 111 | Thanks Bill picture helps a lot, what did you tighten bolts into i noticed that the bolts come out towards block did you drill your own holes?
1959 CHevy Apache
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the bolts are longer ones in place of the rad mounting bolts - double nutted so one nut holds the rad, one holds the shroud - shroud can be drilled where ever you want
Bill | | | | | Joined: Apr 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 111 | would a fan with more baldes actually be a good investment as well? Not so much for overheating issue but just more air flow. I am thinking of buying one alnog with clutch just not sure if it is worth it.
1959 CHevy Apache
| | | | | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | Squeeze,Great pic. Is that a long water pump on that V8 ? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | no idea Giant, it's a friends truck and it's whatever pump was right so all the pulleys lined up on the random used 350 he found for the truck
Bill | | |
