| | | Forums66 Topics128,092 Posts1,056,457 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | I was just wondering if the later model bearing rods (1955 and up) would work on a 1951 235? If so, would any modification be needed on the crank? Is this a common swap? I hear the bearing rods are more effective and eliminate the fear of the pins wearing out and slipping into the cylinder wall like in the earlier models! Yikes! Please let me know...
1946 2 Ton Flatbed
| | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | Nope, impossible! The splash-oil rods have the bearing material bonded to the rod, and there's a big hole in the rod cap to let the oil from the dipper find its way inside. If you managed to get a set of late-model rods and bearings bolted in, the crankshaft would burn up in a matter of minutes due to lack of lubrication.
Wrist pins getting into cylinder walls? Where did you hear that old wives' tale? There have been untold thousands of stovebolt engines made, and probably millions of miles traveled, with no problems with wrist pin clamp bolts getting loose. A mechanic with a bad case of Budweiser fever would be the only thing to cause that problem, I believe. Jerry
| | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | Thanks, Hotrod Lincoln. I expected as much. Oh well.
1946 2 Ton Flatbed
