| | | Forums66 Topics128,094 Posts1,056,048 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | I want to replace new shock absorbers from and back.
I have new set and what should I know about them. Can I do it alone? or is it really two person job?
Please any insight I dont want to get hurt
Ganesh | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | A shop manual is a purchase you'll never regret and awareness of a procedure first makes it more enjoyable and safer than wrenching and waiting for suprises. Here's a link to install/removal instructions: http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0204.html
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Safety first! jack stands and block the wheels, set the brake ect!! Most new parts come with instructions, but if not, note how the old ones are installed and do one side first so you can look at the other side if necessary. Most shocks come "compressed", so when you take the tie off they will extend. So its easier to install them sometimes with the ties left on. If you do untie them you can compress them easy enough. Next best thing your FLAP guy can help. Take your time, easy job once you do it, good luck. | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Curt
Thanks for sending the link, I do have the shop manual. I was trying to find out the tips and tricks.
Ganesh | | |
