4 members (Gdads51, carbking, David Bush, 52Carl), 82 guests, and 9 robots.
Topics128,078
Posts1,056,029
Members48,433
#658324 06/29/2010 3:55 PM
I want to replace new shock absorbers from and back.
I have new set and what should I know about them. Can I do it alone? or is it really two person job?
Please any insight I dont want to get hurt
Ganesh
A shop manual is a purchase you'll never regret and awareness of a procedure first makes it more enjoyable and safer than wrenching and waiting for suprises. Here's a link to install/removal instructions:
http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0204.html
You Tube
Y
Y Offline
Safety first! jack stands and block the wheels, set the brake ect!! Most new parts come with instructions, but if not, note how the old ones are installed and do one side first so you can look at the other side if necessary. Most shocks come "compressed", so when you take the tie off they will extend. So its easier to install them sometimes with the ties left on. If you do untie them you can compress them easy enough. Next best thing your FLAP guy can help. Take your time, easy job once you do it, good luck.
Curt
Thanks for sending the link, I do have the shop manual. I was trying to find out the tips and tricks.
Ganesh
