Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (klhansen, Hotrod Lincoln), 87 guests, and 5 robots.
Topics128,281
Posts1,058,467
Members48,490
1 Offline
My 235 was rebuilt about 3 or 4 years ago and is now in the truck,connected to the tranny ,radiator in, oil and water in. The cab is the only sheet metal on the chassis. I want to fire up the motor before I start to assemble the rest of the sheet metal. I was told that I should prime the oil pump by maybe using an old screw driver cut off that fits the oil pump slot below the dist, turning it slow with a drill. What direction does it turn??? Also if anyone can tell me the basic connections I need to start it . A diagram would be nice . Thanks
i turned the ones i have done clockwise. a simple temp wiring should be pretty easy. 12 volts to starter with cable. off starter thru switch for simple starting circut. 12 volts thru resistor wire to coil. no need for charging circut. good luck
