| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I was working on the 48 and it's rust. I tried using a razor blade then sand paper or a file. I cleaned it up and sprayed some primer. Looked good.
I am a experimenting but this looked good.
And extremely slow. I want to live a long time.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Dawg, put the pipe away and try again.  | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Hey Woody. What is your suggestion?
| | | | | Joined: Oct 2009 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 40 | I don't get it, what are you asking? Are you looking for rust suggestions? Eastwood rust encapsulator is a very good product I have used it many times and works well. As far as removing rust, I would always sand blast it, remove every last bit of it. If it comes down to it cut the rust out and weld a new piece of steel in. | | |
