0 members (),
100
Mod | | | Forums66 Topics128,080 Posts1,056,317 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Today I jacked one rear wheel off the ground and turned the wheel one full turn, the drive shaft moved a little over 2 revolutions, this doesn't sound right but that's what happened? 41 1/2 ton. Any thoughts here. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | 4.11 seems probable. How are you seeing the driveshaft spin? doesn't your 1/2 ton have a torque tube?
try spinning the wheel twice or even more like 20 times and then devide by 10. sounds complicated but it isn't. the spider gears are taking up 1/2 the travel. so if you spin the wheel twice, you will get a more accurate picture. 20 times even better. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I have the engine and transmission out so I'm lookng at the universal sticking out of the torque tube. Can you explain why I would divide by 10 if I spun the wheel 20 times. I thought if it was a 4.11 the drive shaft would spin 4.11 times for every turn of the wheel. I may have just showed my ignorance. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Its helpful to think about it the way power is applied. When power is applied to the differential by the engine the differential allows the rear wheels to turn at different speeds. When one wheel can not turn the other turns at twice the gear ratio.
So if your ratio is 4.11 that means the drive shaft turns normally 4.11 times for every time the axle turns, or 2.055 times if one wheel is stopped.
Here I think bigbad misspoke. If you stop one wheel and turn the other ten times, you should count 20.55 turns of the drive shaft. Now divide by half of ten, and you'll get the correct ratio, or 4.11
The more turns the easier it is to get an accurate number, but if you have looked up the probable options you rarely need more than a turn or to to narrow it down the the most likely ones.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Are you saying that if I lift both wheels off the ground and spin the drive shaft the wheels will turn 1 revolution for every 4.11 turns of the driveshaft. But, if I stop one of the wheels I will get one wheel revolution for every 2 plus turns of the driveshaft. I don't get it but will accept it. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | If you spin the wheel 20 times the this should simulate both wheels spinning 10 times, but your driveshaft should spin something like 41 times if it is a 4.11 or 45.5 if it is a 4.56 ratio. This simple action eliminates some of the guesswork and error | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Thanks, I still don't understand the reason for it but I'm going to study up so I understand it, know of any good reference material? Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Are you saying that if I lift both wheels off the ground and spin the drive shaft the wheels will turn 1 revolution for every 4.11 turns of the driveshaft. Unless you have a locking differential you can't count on that. If you have a locking diff that is exactly what would happen. Because of the way the differential works most approaches to counting revolutions have one tire securely on the ground and require a little math to determine the ratio.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If you spin the wheel 20 times the this should simulate both wheels spinning 10 times Given how rare lockers are in those early years you really need to have one wheel on the ground and do the math.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2010 Posts: 4 New Guy | | New Guy Joined: Jan 2010 Posts: 4 | A differential will transfer the power to the wheel with the least amount of traction,Both wheels on the ground the power is applied equally to both wheels. Now lift one wheel off the ground ,while leaving the other on the ground all the power is transferd to the wheel in the air.and will turn twice as many times.
So when you turn the wheel,lets say 20 times and count the turns on the pinion shaft,you have to divide by 10(or half as many times as you turned the Wheel) to get the gear ratio.
"ol'krud" 1953 3100 | | |
