| | | Forums66 Topics128,156 Posts1,057,021 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 126 | I finally got my engine back in my '66 C10. I bit the bullet and shelled out the dough for an Offy with 2 carbs and cast iron headers from Langdons, which means I now get to fabricate/re-route/generally mess with various linkages etc.....I've got a plan for the fuel lines, but the water lines for water heating the intake are troubling me. I don't want a nest of snakes with hoses and wires etc everywhere, so I am trying to avoid just laying a couple hoses off of the heater system over the valve cover. I'm thinking maybe I will run a T fitting off the thermostat and water pump heater lines, and then run copper tubing to the manifold.
Anybody got any advice or better yet pictures of how you got your water to your Offy manifolds on a straight six?
Thanks. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | You have two options. First is running water lines off the water pump/therostat housing or running them off the exhaust. I did the exhaust for two reasons. First in theory, the exhaust will heat up much faster than water to do what it is designed to do. Finally, its much closer, making for a cleaner look when complete. Here is a pic of what I did.... My 261 Engine....
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
