4 members (Gdads51, dt235sd, baldeagle, Mike Roache), 171 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#6573 10/12/2003 12:26 PM
k10
Offline
I have a new heat riser spring for my 228. It's installed according to the service manual. It's got a 1/3 of a turn on it, as per the manual. There's only one problem. It seems to me that it's holding the flapper in the "hot" position while it's cold. Meaning that the weight is flopped toward the driver's side. I thought that was the warmed up position. And that the "vertical" position was the "closed" or "cold position". The spring is from Bowtie bits and it looks identical to the one shown in the shop manual. Just tell me I'm wrong and that everything's right. What? grin
Please send pictures.
Hello K10
I recently replaced the exhaust on my 228 GMC and I did determine that the exhaust manifold flapper that directs heat to the intake manifold was CLOSED when the flapper weight was toward the PASSENGER side.
If I understand your post correctly, your install is correct.
