7 members (cmayna, Otto Skorzeny, oldsteve, Hanks custodian, Stovebolt48, gswbbc, Maybellene),
143
Mod | | | Forums66 Topics128,042 Posts1,055,520 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | On a 46 Chevy 1/2 ton can some one tell me where the brake pedal return spring hooks?
Monroe McKill
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Monroe Mckill, welcome, the spring attaches to the clevice pin via a clip or tab which slips over the pin and is retained by the cotter pin at the bottom of the pedal, and to a clip or tab bolted to the left rear transmission shift tower retaing bolt, hope that helps. | | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | Thank you. I have a truck that shows only 42000 miles and has not been run in a long time. I plan to grease it and go over it before I try to drive it. It is nearly a rust free truck and will make a nice one to drive. I may have to come back for a lot more help as I get farther along. Monroe
Monroe McKill
