3 members (66flea, BC59, dt235sd),
184
Mod | | | Forums66 Topics128,087 Posts1,056,106 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 27 New Guy | | New Guy Joined: Nov 2006 Posts: 27 | Is there something that one can use to bleed brakes by one person. Lots of pedal and air. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | You can buy a special tool that makes it a one man job. Not sure of the cost. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Nov 2006 Posts: 27 New Guy | | New Guy Joined: Nov 2006 Posts: 27 | Wow,
You guys again. Very helpful. Tim, you knew where I was also heading with that question. Hydro-vac on the big truck.
Right category this time.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I have one of those I use at work, mine has the "universal adapter", which isn't so universal. Great tool, though. Easy to use and does a great job.
Bill Burmeister | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Phoenix brake bleed system uses reverse technology for bleeding brakes. That should work I guess, they DIY priced one and professional one
Ganesh | | |
