6 members (delwrench, FAST55, RaNfLaS, rfs56trk, Rusted Nut, mick53), 240 guests, and 3 robots.
Topics128,086
Posts1,056,101
Members48,434
#656657 06/22/2010 10:51 PM
Is there something that one can use to bleed brakes by one person. Lots of pedal and air.
You can buy a special tool that makes it a one man job. Not sure of the cost.
1940 Chevy KC 1/2-Ton
Bruce,
If you have hydro-vac on your big truck, you will need this pressure bleeder (a one-person unit that also works on non-hydra-vac trucks):
http://store.motiveproducts.com/classic-american-and-marine-trailer-bleeder--0102-p27.aspx
Here are other one-person options:
http://www.speedbleeder.com/
http://www.russellperformance.com/mc/speed/domestic.shtml
http://www.harborfreight.com/catalogsearch/result/?category=&q=bleeder
Wow,
You guys again. Very helpful. Tim, you knew where I was also heading with that question. Hydro-vac on the big truck.
Right category this time.
I have one of those I use at work, mine has the "universal adapter", which isn't so universal. Great tool, though. Easy to use and does a great job.
Bill Burmeister
Phoenix brake bleed system uses reverse technology for bleeding brakes. That should work I guess, they DIY priced one and professional one
Ganesh
Moderated by  MNSmith
