6 members (bucktruck, dt235sd, Stelonlevo, Hotrod Lincoln, Mike B, 1 invisible), 104 guests, and 2 robots.
Topics128,119
Posts1,056,648
Members48,450
Im wandering if anybody chaged axles to get new bolt pattern on front and rear and what axles were used.My truck is 1964 c60 with a 19995 maximum weight with single duals. my bolt pattern is 8.75 and pilot hub is 6.25. Is that bigger than a 2 ton.?
Even a fool is thought wise if he keeps silent, and discerning if he holds his tongue. proverbs 17:28
First off what's the goal?
Why would you like to have a different bolt pattern?
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
I would like to get away from man killers, and get a wider variety of tire sizes.
You can still purchase new steel 22.5" tubeless wheels with that bolt pattern from Accuride.
Check this tech tip for a link to the Accuride catalog
http://www.stovebolt.com/techtips/wheels/
You can also find them used in junk yards.
more on the subject
https://www.stovebolt.com/ubbthread...p;Words=28160&Search=true#Post652296
https://www.stovebolt.com/ubbthread...p;Words=28160&Search=true#Post628631
Grigg
---All pictures---
