1 members (Rusty Heaps), 114 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#656389 06/21/2010 5:36 PM
I´m tryng to find local seller for the inner and outer front bearings for my 1952 chevy truck 3/4ton. Does anybody help me with the measurements of both bearings?
In my understanding there is a modern bearing what sustitute the old outer one.
I´m not from USA.
Thanks guys,
alfonso
Try NAPA.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
3B Offline
Hy alfonso, I don't have the dimensions, but I believe the part numbers are, inner 909026, outer 909025 those are the numbers for the entire bearing assembly, three pieces for each bearing. Those are the original ball bearings, some companies used to make tapered roller bearing replacements for those, the part numbers for those were, inner 909026R, outer 909025R, I have had no luck trying to locate the tapered replacements using those numbers, but they were good numbers at one time, hope that helps.
3B #656566 06/22/2010 1:16 PM
Of course you help me 3B, I will try.
Thanks again,
alfonso
