0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 46 New Guy | | New Guy Joined: Apr 2006 Posts: 46 | My metal 12 tooth driven gear broke off it's shaft, and the teeth are deformed (don't know what the drive gear looks like). I've looked at the usual websites but can't find anything that even looks close to mine. Anybody know a source, or do I have to go out to the junkyard?
1953 GMC half-ton
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1953 GMC What size truck? What transmission?
I think the drive gear is the one inside the transmission and the driven gear is at the end of the cable fitting that goes into the transmission.
A Want Ad in the Swap Meet with the above information might get you the used parts (and/or, get you a response from people with NOS parts - I got mine that way).
| | | | | Joined: Apr 2006 Posts: 46 New Guy | | New Guy Joined: Apr 2006 Posts: 46 | That sounds more logical about the driven gear. Thanks. I'm driving a half-ton 228 6 cylinder with 4 speed (granny gear). I'll try posting.
1953 GMC half-ton
| | | | | Joined: Nov 2000 Posts: 171 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 171 | Are you having troubles with the transmission gears [take off for speedometer] or the speedometer head it's self? the inner parts of the speedometer are fairly much all the same among GM cars in the 50's
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | GMC53, check your Private Messages. I have sent the name/number of someone to contact.
