5 members (Steelonsteel, Gdads51, Wayne67vert, TUTS 59, Mike'sPlace), 85 guests, and 3 robots.
Topics128,065
Posts1,055,870
Members48,428
Okay, at the risk of sounding like a total novice how do you test the Batt gauge?
I'm a fabricator/bodyman type and now that all of that is behind me I'm sure I'm going to be posting some pretty dumb questions so I ask for your forgiveness in advance. frown
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Easy way to check is take you're truck battery and you're gauge and a small battery charger
1- neg. from charger to neg battery post
2- pc. of wire from pos. of battery to right terminal on gauge as you're looking at it
3- pos. from charger to left terminal on gauge
The gauge should show the charge flowing to the battery
Pete
Are we talking about a voltmeter or an ammeter? The voltmeter is easy- - - -just connect it across the terminals of the battery, and it will indicate the voltaqge if it's in good shape. An ammeter needs current flowing to show a reading, so it needs to be in series with the circuit you're using. Is the gauge installed, or out of the truck? If it's in the dash and the wiring harness is intact, disconnect the wire at the "Bat" terminal of the voltage regulator and attach a battery charger red connector to the wire, and the black connector to ground. Turn the charger on, and the ammeter should show a charge. Connect a headlight bulb to that wire and ground, and the gauge will show a discharge.
If the ammeter is out of the truck, the same procedure will work, just put the gauge in the circuit so the current has to flow through it to do the charge/discharge thing.
Jerry,
This is the stock gauge from a '51 AD, see subject title. Not knowing the difference between a watt and an ohm I referred to it by the name on the instrument cluster... Batt.
Sorry for any confusion.
Woody
Door Art Collection
OK, that's an ammeter. Use the procedure I described to see if it deflects side to side as current flows through it. Don't expect a very accurate reading, about all a stock meter does is indicate whether or not current is flowing, and which way it's going.
The only dumb question ,is the one that isn't asked. dang
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Anyone who deals with the public knows that's simply not true grin
Woody
Door Art Collection
HAHAHAHAHA!
Dave
That's why I don't deal with the public. nono
1953 Chevy Two-Ton
