0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 23 New Guy | | New Guy Joined: Feb 2008 Posts: 23 | I have completed 1953 31oo chevy. Have 56 235 in. Starter sometimes clashes with flywheel. I remember these noises back when. My age is now given. The flywheel is damaged. The somewhat blunt end of what I call Bendix teeth is hitting fly/wh. and not carring thru,(engageing_. with stamp starter I should be able to force thru to flywheel before amps are applied via switch on starter with tapered teeth on starter. Do I need to randr starter and file, grind teeth to beter taper on starter. or flip fly/wh the only way
Plattelnjpichler
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy sepp22, could you possibly have inadvertantly mixed a 12 volt flywheel with a 6 volt starter, or visa versa? | | | | | Joined: Jun 2000 Posts: 738 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 738 | I moved you from Welcome Center to here, I hope this helps. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You prbably need a new drive on the starter. Every time you here the noise you lose a little more of the ring gear. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I would flip the ring gear and install a new starter bendix.Make sure you are using the right starter for the flywheel. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | Are you using a 6V or a 12V starter? There's a difference in the number of teeth on the flywheel, and the starter drive pinion, so the starter and the flywheel must match. It's OK to run 12 volts against the 6V starter, as long as you don't crank for an extended period of time, but the starter and the flywheel MUST match. The 56 flywheel will be set up for 12 volts, so you'd need to be sure to use a 12V starter, or use a 6V starter and swap to the flywheel for a 54 or earlier engine. Jerry
