| | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 1 New Guy | | New Guy Joined: Jun 2010 Posts: 1 | Does anyone have either the particular pieces of hardware, or have close-up photos of the way a 1959 Chevy Suburban "Carry All" front passenger jump-seat bolts down to the floorboard? Any help or parts would be GREAT!
"There will be plenty of time to sleep when you're DEAD...now get up and go wrench on something"
| | | | | Joined: Apr 2006 Posts: 136 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 136 | AZ; There should be a detailed picture in the factory assembly manual. I assume my '58 GMC Suburban jump seat is the same as yours. If so, I can take a picture in the morning and email it to you. | | | | | Joined: Apr 2006 Posts: 136 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 136 | AZ:
I sent you an email with 3 photos of the mounting brackets and bushings, as well as references to the factory assembly manual. Hope this helps!
Mark | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Easy, easy, to make all that. I'm in AZ too, where in AZ R U?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
