5 members (Hotrod Lincoln, fonz8261, baldeagle, walter74, 1 invisible), 97 guests, and 2 robots.
Topics128,134
Posts1,056,416
Members48,441
#656041 06/20/2010 2:31 AM
I bought a frame mounted power brake set up from Master Power Brakes...when I installed it I had to do some mods to my tranny mount ...mainly notching it so the master would clear....I also had to switch the combination valve from the left to right side so it would clear the mount as well.This threw off the orientation of the fittings on the u shaped brake lines....
I called MP Brakes to see if a different line was available...they could have cared less about my problem...I explained I was fully expecting to pay..They Flat didnt give a rats a$$... I wish I would have seen this side of them before....they sure didnt mind taking my $600.00....The line was kinda small so I had One shot to switch the fittings..I cut and flared the first one ok but blew the flare on the second one...the radius was to small for me to duplicate.
I saw on Inline Tubes website that they did custom duplication,so I gave them a call...I spoke with Chuck who gave me instruction as to sending it to them...He called when he recieved it and after deciding what materials I wanted,informed me it would be $10.00....plus $5.00 more to ship it...This was on wednesday..I recieved it friday...it was a perfect fit....They have helped me out before on some fittings I couldnt find elsewhere.....Their customer service is over the top...I reccomend them highly.......dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
thanks for the info Dave. always like to hear about vendors that go over the top.
Haven' heard of that vendor before and I'm not exactly sure what you bought but I just wanted to say that I've had really good experiences with ABS brakes in Orange, CA. http://www.abspowerbrake.com/index.html
I realize this is one of those "...now you tell me!" deals but I just thought I'd mention it anyways. I've purchase a number of products from them (disc brake and power steering kits) and they are pretty good. The owners are knowledgable and will talk to you and help you as well. Appreciate the tip re Inline Tube. Best of luck with your projects.
