2 members (dt235sd, Jon G), 50 guests, and 4 robots.
Topics128,021
Posts1,055,372
Members48,420
#654978 06/15/2010 7:11 PM
rar
Offline
i have 65 gmc that i want to change steering columns to later model tilt. what years do i need to look for. tks
rar #654996 06/15/2010 8:15 PM
Do you want to leave the ignition in the dash? A lot of the vans up to the early '80s should work with minor modifications.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
I have a tilt wheel column out of a 1988 full size pickup that had floor shift
BILL #655141 06/16/2010 6:05 AM
By '72 a tilt column was an option in the pickup. The ideal answer would be one of those early columns or the van column as already suggested.
Otherwise you are looking at locking column options and most any rear drive GM tilt column can most likely be adapted.
OldSub #655476 06/17/2010 4:39 PM
I have a tilt column out of a mid-eighties Chevy Van - ignition key still goes in dash
1940 Chevy KC 1/2-Ton
Britcon #655692 06/18/2010 7:38 AM
rar
Offline
thanks for info, i will let you guys know when i get one installed. thanks again. 65gmcrick
rar #657838 06/27/2010 10:02 PM
Sir Searchalot
Sir Searchalot
I would like to find a no key tilt for sale.
bartamos #657901 06/28/2010 1:22 AM
Advertise in the swap meet or look at aftermarket options.
bartamos #657978 06/28/2010 4:22 AM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
I would like to find a no key tilt.
Make one, I've done it several times.
Get the column you like.
Remove the ignition tumblers & steering wheel locking mechanism.
Grind off the numb from the ignition tumblers and fill the hole.
I used JB Weld & finished it up w/some bondo.
Sand everything smooth & paint it your favorite color.
Heck I made a 94 GM FWD tilt column look like it could have came out of a mid 70's GM car/truck.
In the future I may remove ignition tumblers & steering wheel locking mechanism and smooth everything out(this column) but I haven't made up my mind yet....joe
Last edited by ZooKeeper; 06/28/2010 10:43 PM. Reason: clearing up a miss understander
#658117 06/28/2010 8:36 PM
Sir Searchalot
Sir Searchalot
That's a great idea. thank you. I don't get your last sentence? You have done it but you are going to do it?
bartamos #658163 06/28/2010 10:42 PM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
I have done it in the past to several other columns.
On the link I made the 94 FWD column to look like a 70's GM column but hadn't decided if I wanted to remove the ignition tumblers or not on this column...joe
#658281 06/29/2010 10:06 AM
Sir Searchalot
Sir Searchalot
thanks Joe, good job. I will do that cut off, plug hole thing.
