| | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | does anyone have any recommendations as to what oil should go in the transmission and rear end. I've heard newer oil contain additive that damage older transmissions and rear ends. True or False? | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy Bakerallen, 80 - 90 wt. I believe was specified, hypoid lube, the higher the number the thicker when cold, most are multi weight now, hope that helps. | | |
