4 members (Gdads51, MickeyP, TUTS 59, Otto Skorzeny), 23 guests, and 5 robots.
Topics128,013
Posts1,055,312
Members48,419
#654850 06/15/2010 3:45 AM
327, good compression. Just replaced timing chain, starts idles good. Tried every tuning trick i know. Runs the same as before chain swap. No popping back, very dead on bottom end, acts like low vaccum.Runs good after up to speed, but seems like you have to "ride" it all the time. This used to be a real go getter. Has my cam played out?
blu 64 #654858 06/15/2010 4:04 AM
What is the vacuum reading at a steady throttle setting, maybe 2,000 RPM in neutral? If it's under 18 inches of mercury, you've got the timing chain one tooth out of time. A quick way to check this is to take the passenger's side valve cover off and watch the #6 cylinder valves as you turn the engine over slowly. The exhaust valve should be closing, and the intake just starting to open, as the timing mark aligns with top dead center. (0 degrees). I'm going to predict that the intake valve will be open way too far as the TDC mark lines up, from the cam being one tooth late on the timing chain alignment.
Hotrod Lincoln #654907 06/15/2010 12:57 PM
X2 - sounds like the cam is retarded.
