1 members (Millenimech), 118 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
#654830 06/15/2010 2:42 AM
I have a couple questions about wiring my 12v 54 1/2 ton.
Is it ok to run a heavier (10 gauge) wire from ignition to gas gauge? Does there need to be a ground wire from gas gauge to frame, if so, which terminal?
I don't know the circuit for your truck, and I'm not sitting in front of my truck or a schematic, but a heavier gauge won't hurt. 10 is a little big, though, do you have extra or something?
I found the wiring diagram for your truck , and it says one side is grounded the other hot, so its a variable resister device. 10 gauge might alter your final reading, but I'd just try it and add some resistance later if needed. Or you could just spend a buck and use 18ga.
Dave
