1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | Hi. I was wondering if anyone can help me out with an explanation or maybe a simple diagram for wiring a pressure switch for an electric choke on the holley weber set up. I have napa switch #op6626 (thanks tclederman!) just want an opinion on the best way to get power to the switch. Thanks for the input. John
John 50' chevy 3100 shortbed
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | John,
I think that I ran mine from the BATT lead on the voltage regulator (through a 10amp in-line fuse). I do not know if this is the best way but it was the easiest for me. I'll double-check this tomorrow and correct this if I am wrong.
| | | | | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | Tim, Thank you very much!! I appreciate your help and knowledge. John
