2 members (Tstan7, Napco Mark), 75 guests, and 6 robots.
Topics128,022
Posts1,055,353
Members48,420
#654521 06/13/2010 11:29 PM
Hope you guys can help. Is a 53 powerglide 235 a full oil pressure engine?
Dustman #654531 06/13/2010 11:58 PM
Yes, the first one.
Dustman #654545 06/14/2010 1:25 AM
If you are looking at a specific engine, check the casting numbers to be sure the Powerglide trans wasnt added later. I bought a non-pressure '53 235 that had a Powerglide on it, which as I said, was changed later from the original 3 spd.
http://clubs.hemmings.com/clubsites/chevytalk/GMhistory/1916-57cast.html
1946 Chevrolet 1/2-ton
More pix on Photobucket
Big Tee #654565 06/14/2010 2:37 AM
Be sure you look at the block above and behind the starter if it is a full pressure engine it will have to vertical bars about 1/4" wide and 1" high cast onto the side of the block. They are visible with the starter in place.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Kip's41 #654671 06/14/2010 5:10 PM
Look at the serial number stamped onto the pad just aft of the distributor, the '53 'glide motors began with LAQ, or LAS
waldo53 #655064 06/16/2010 12:33 AM
Thanks for the help, gentlemen.
