1 members (Otto Skorzeny),
105
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65448 09/09/2006 4:10 PM | Joined: Jul 2006 Posts: 34 Junior Member | | Junior Member Joined: Jul 2006 Posts: 34 | I currently have the engine and transmission out of my truck to re-seal everything. Can anyone tell me the details on the first gear. Did this gear have syncro to keep it from grinding. I thought while I had it out I could get that looked at.
shor Cooking Turtle Soup today! | | |
#65449 09/09/2006 4:35 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | | | |
#65450 09/09/2006 5:43 PM | Joined: Jul 2006 Posts: 34 Junior Member | | Junior Member Joined: Jul 2006 Posts: 34 | Im sorry its the original 65 | | |
#65451 09/09/2006 5:50 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Thought that there should be a synchro first that year. Didn't they start about 1962? | | |
#65452 09/09/2006 5:54 PM | Joined: Jul 2006 Posts: 34 Junior Member | | Junior Member Joined: Jul 2006 Posts: 34 | Well not sure about that. That is why I was asking. The syncro usually means all 3 gears.
shor Steve | | |
#65453 09/10/2006 12:42 AM | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | If your 65 has the original Muncie transmission (4 bolt side cover) it is not syncro in first gear. Chevy offered a full syncro overdrive trans in 66, but the regular one was non syncro. To the best of my knowledge the full syncro 3 speed (Saginaw) was not introduced until late 67. It is common to install one of the later transmissions in these trucks and you may have one. They are much larger and have 7 bolts on the side cover. Fred
#65454 09/10/2006 4:21 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | | | |
#65455 09/11/2006 2:47 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's most likely an SM318, non-syncro 1rst gear. These aren't too bad to overhaul. The gaskets can be had fron Napa and there are several on-line sources for hard parts. The full syncro was either '66 or '67. Technically, they are both considered Saginaw transmissions, the high performance 4 speeds are the only ones officially called Muncies by GM.
Bill Burmeister | | |
#65456 09/11/2006 4:13 AM | Joined: Jul 2006 Posts: 34 Junior Member | | Junior Member Joined: Jul 2006 Posts: 34 | Well then I am going to leave well enough be. I will change the O-ring seals, paint it and stick it back in. Thanks guys Shor Steve The turtle soup is awesome.  | | |
#65457 09/11/2006 1:13 PM | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | I have a '62 3sp+ od B-W transmission which essentially is what you have (-the od). Use the 2nd or 3rd gear synchros to stop the transmission and smoothly shift into 1st every time. You'll never 'grind gears' again.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#65458 09/11/2006 3:33 PM | Joined: Feb 2001 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 81 | COSMO-I HAVE THE SAME TRANSMISSION AS YOU IN MY 62 CHEVY 1/2 TON FLEETSIDE. I AM HAVING TROUBLE IN THAT THE TRANS SLIPS OUT OF HIGH ON A SLIGHT HILL SOMEWHERE AROUND 60 TO 65 MPH. ANY IDEA AS TO WHAT CAUSES THIS?I TOO DO NOT HAVE A SYNCHO FIRST GEAR. I TRY TO DOWN SHIFT TO LOW BEFORE I COME TO A COMPLETE STOP-PREVENTS GRINDING EVERY TIME!
Green Machine
#65459 09/11/2006 4:20 PM | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Generally when these transmissions pop out of 3rd it is because of wear in the syncro. Also, the small spring ring on the clutch gear could have some wear. Check for bad u-joints and/or driveshaft carrier bearing that can cause a vibration that will also cause it to fall out of gear.
#65460 09/11/2006 4:31 PM | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | I find that if I shift into first right after I have come to a complete stop no problem. However, If I am going to be at the stop for a while, I will take it out of gear and sit in neutral. When I am ready to go, I need to shift into second then first to avoid grinding first gear. I don't go at all while in second, and the clutch pedal is down all the way the entire time. Years ago, I don't remember having this problem of shifting into first at a complete stop, but others described this problem with shifting into first gear. I had no idea what they were talking about until a couple of years ago when I started driving the truck again, and I had the same problem.
58 Fleetside, 235, "The Old Buckin' Bronco"
#65461 09/11/2006 11:45 PM | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | MR. shor, apologies if we are hijacking the thread but this is all good info. What rfs56trk said, and under the 4 bolt shift cover plate you'll see that which keeps the gear is a small machined depression and a spring-loaded ball affair... one for 1st-rev, the other for 2nd-3rd. These springs are now 50+ years old and in all probability have lost considerable 'memory' (the ability to return to original shape). I submit that this also leads to popping out of third at highway speeds.
