| | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 44 | Hey guys!
I've got a '49 GMC I'm tinkering with and fixing up. Over the past or so I've been collecting parts and working towards getting it on the road.
My question is, I would really like a radio. But, I have yet to find a GMC radio, and I can't afford the Jim Carter price. I'd like to find something I can fix up (used to work in a electronics shop).
Can a Chev radio be switched over to a positive ground circuit? Simple? Difficult? Impossible, or even worth it?
I ask because I've seen a couple at swap meets and on ebay, and I'll do the work if I can save a few bucks.
Thanks! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | 78Chev, the radio for the GMC and the Chev are basically the same radio with a different dial display. You can buy a new dial glass to change it to GMC. The original radios had a mechanical vibrator in the power supply and the radio would run either with positive ground or negative ground. Now days you can buy a solid state replacement for the vibrator and you would need to make sure it was for the correct polarity that you want.
There were two different designs that were made, one from 1948 to 50 and another from 51 to 53. They are interchangeable in application. The older one has the back cut on an angle (slant back) and the newer one has the straight cut back. The dials are different so it is good to get the correct dial glass to have the stations align properly.
If you get to restoring one, we can help you out with answering all your questions. | | | | | Joined: Nov 2000 Posts: 171 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 171 | I swap Chevy/GMC radios all the type for Jim Carter , I you really want to get close I can get you a GMC model/serial # plate for 47-49, BILL | | | | | Joined: Apr 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 44 | Thanks guys! I've been looking at one on ebay for about 300 bucks, seems like a good price, but a little steep for me right now. At least I know I can look for either.
