3 members (Woodcmiami, Cosmo, 1 invisible),
75
Mod | | | Forums66 Topics128,150 Posts1,056,991 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | my wife was following me on the interstate, and wasn't keeping up with me. I asked her why and she said it's a 65 mph zone and I was speeding. I didn't know as my speedo doesn't work. but that made me wonder: am I supposed to be able to do 70 with a 1959 1 ton? as far as I know I'm all stock (except for the alernator). | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | How were you doing with other traffic? Around here you will get run over doing the speed limit and I would estimate the general public runs at least 5-10 mph over the limit. Just because she was in a newer car doesn't mean that her speedometer is right either. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | a 1T with 5.14 gears and a 235 would be pretty much screaming and you'd be pushin the pedal hard to the floor unless you were on a long downgrade .... I'd suspect the car speedo too, but might be worth checking the actual rear ratio, they came out with "fuel saver" ratios for the 1/2T in 58, might have had better gears for the 1T as well, or you might actually have the 3/4T 4.57 rear
Bill | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | How tall are your tires? With your tire height and gear ratio you can calculate speed at RPM using one of the online calculators.
70 with the stock gearing and tires with a 235 seems pretty fast, but I would not say its impossible.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | Time yourself over a measured mile at a relatively steady speed. 60 seconds for one mile = 60 MPH. For other speeds a little simple math will get the job done. For instance- - - - -a 50-second mile would compute as follows: 60 divided by 50 = 1.2 miles per minute. 1.2 X 60 = 72 MPH. A 70-second mile = .85 miles/minute, or 51 MPH.
70 MPH, unless you've got the extremely scarce 4.11 ratio rear end gears, would be a stretch with a 1-ton with normal-height tires. My 59 model 3800 dually with 18" wheels had a hard time maintaining 65 MPH for very long. Jerry
| | | | | Joined: Aug 2007 Posts: 8 New Guy | | New Guy Joined: Aug 2007 Posts: 8 | just check it with a GPS. | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | 'Tater will do 60 on level ground, and that's with a bone stock 270ci L6, SM-420, 8.5:1 (in high), on 8.25x20 wheels. I try to keep her around 55 so I dont start ejecting random parts. :P
Had my old 3/4 ton runnin 16.5" wheels and a 5.3ish:1 rear end that would roll at 80 all day long without issue. RPM's were up around 5K, but it was a 327 V8 pushing thru a 4-speed car trans.
1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | If it has 17" tires, 70 mph is not all that fast. In 1962 Texas raised the speed limit from 60 to 70 and of course had to lower it to 55 in the mid 70's. We drove the speed limit and more in those days. We just disregarded the noise and vibrations. Engines don't fly apart when operated in the 3,000+ range, even though they may sound like it. As long as you have a good radiator to keep them cool, a stock carburetor won't give them enough gas to over rev them to dangerous levels. For us old geezers who got their drivers license in the 50's, having to slow down to 55 in the 70's was a real pain. | | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | I guess the absolute answer is still up in the air. I've done the milemarker timing, and I've passed other cars on the interstate. I do have 19.5 tires. I'm not even flooring it completely. And the only breakdown I ever had was when I had a major vacuum leak combined with a clogged radiator which led to a piston with a dime-sized hole in it. Since then I got a new radiator and flushed the whole system, and the oil has always been clean. I guess it may just be running really well  | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The 19.5 tires are part of the answer. Your tires are quite tall. If you can measure the height of one of your rear tires you can use that and assumptions about what rear gears you have to estimate RPM at Speed.
If I had a height for a 19.5 I'd already have those numbers in a table in this reply.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | hey I see some of you mentioning even size tires (17, 18) for the Task Force trucks. aren't the even numbers split rims and the odd (like my 19.5) 'normal' rims? I thought all TF trucks had regular rims?? | | | | | Joined: Apr 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 126 | just check it with a GPS. best idea- have a gps in one of my trucks, its actually easier to see the speed than looking down at the cluster, plus since the tire height was changed the speedo is off, and i only noticed it by the gps. only off by about 4 mph, but enough for a cop to ticket me (if he is an a-hole). but yeah, gps is best.
66' Chevy C-30 Rat
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If curious what the gear ratio is why not jack up a wheel, count some turns, and do the math??
Grigg | | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | I've had my '62 1 ton to 70 mph on the flat and downgrades but it did not sound happy so I didn't keep it there. It has a 235, 5.14 gears and 7.00 X 18 tires
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | To my modern ears accustomed to very quiet motors and even quieter cars, I suspect what sounds like its about to fly apart is really nothing more than working it a little hard.
What limits my speed is the old suspension and steering more than the motor.
I wouldn't push a babbit motor but remember guys used to race those against flathead Fords back in the day.
