2 members (Otto Skorzeny, 1 invisible), 92 guests, and 2 robots.
Topics128,031
Posts1,055,433
Members48,422
I recently ordered a power steering conversion kit from CPP (5559-blk). Trouble I'm having is that the steering box it says to use, doesn't seem to work. It says 1967-1987 Chevy 2wd truck. Other sites I have looked at that sells it has other years and designations for the box. I figured I'd go with what CPP said. Ordered a remanned box from off ebay and it was a steering input shaft that is way smaller than the 13/16" 36-spline shaft it is suppose to use.
Been looking at a lot of other boxes from the year range stated and they all pretty much look the same as the one I got.
Am I missing something? Is CPP's info not straight? What is it exactly that I need to look for, it's pretty apparent that it isn't as easy as 1967-1987 2wd.
Any help would be greatly appreciated.
Riding in the Passing Lane
They used 2 different size shafts on those. If you get the rag joint coupler to fit your shaft it should work.
1972 Chevy c10 Cheyenne Super
There are also both SAE and Metric hose fittings depending on the year of the box. You need to know when one you have before you order hoses.
bringing this back up because I did get the kit installed. I installed it at the same time I installed CPP's disk brake conversion kit.
Now that it is installed, it appears that my turning radius will be greatly reduced due to potential for the tire to rub the steering box.
I had to switch to after market wheels and wentto radials because of the disk conversion. Tires are 235/85R16 (closest to the stock size bias plys I could find). The inner sidewall is only about 3.5"-4" away from the steering box.
Has anybody else had any experience with this? Suggestions?
I've thought about different offset wheels, but not really liking that option. Especially since I already bought new wheels.
