4 members (Shardean, Tstan7, 2 invisible), 94 guests, and 4 robots.
Topics128,022
Posts1,055,353
Members48,420
#65408 09/07/2006 8:53 PM
Junior Member
Junior Member
Greetings,
I installed power steering on my 58 chevy and used a Saginaw gear box off of a 1977 pu is what I was told. The problem is I can not hold it in the road. The steering is so touchy that it goes crazy with the slightest wheel movement. Does anyone know of a box with a different ratio that might do better. This thing is a danger on the road.
Paul
Paul
When you do a good deed, get a receipt just incase HEAVEN is
like....the IRS
#65409 09/07/2006 9:16 PM
Have you set the toe in?
My Blog
#65410 09/07/2006 9:17 PM
taz101,
Although not real familiar with a '58, here are a few thoughts.
On my '51 AD with straight axle, I installed a Saginaw box out of a '76 Nova. This was a police car and the box was a COPO (?) quick ratio unit.
The truck handled very well at all speeds on most roads.
Did your basic steering geometry stay the same. The pitman arm and steering arm should be in almost the same plane.
Could it be a alignment issue. Are there other front end components that could be worn.
Stuart
#65411 09/07/2006 9:27 PM
Riding in the Passing Lane
You may have gotten a bad steering gear. There is a little tortion bar in those. When it breaks the steering gets real sensitive, turns with the slightest touch. Let us know how it turns out. I,ve been contimplating the same swap.
1972 Chevy c10 Cheyenne Super
#65412 09/07/2006 11:28 PM
Are you running a pump to match the pressure/flow requirements of the gear box?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#65413 09/26/2006 9:19 AM
Junior Member
Junior Member
Hi Guys,
Sorry I took so long to reply with answer to steering problem but I have been gone. Toe in was the problem. I was not even close measuring it to get in the ballpark.
Does great now. Thanks for all the help.
Paul
Paul
like....the IRS
#65414 09/26/2006 10:45 PM
What kit did you use?
