0 members (), 67 guests, and 5 robots.
Topics128,271
Posts1,058,313
Members48,485
#654070 06/11/2010 9:38 PM
What 6-volt distributor for for a chevy v-8.? Can a 12 volt starter be re-wound to make it a 6 volt? Thanks bob Fortner
bob fortner #654076 06/11/2010 9:59 PM
none and no ... if you're going to a V8 in a 6 volt truck then you're also looking at changing to 12V - [and it's actually the coil that's 6 or 12V, the dist doesn't care]
might help to state a bit about what you're working with and what you want to end up with
bob fortner #654188 06/12/2010 4:55 AM
Yes, it's possible to rework a V-8 starter for 6 volts. Any good starter/alternator rebuilder worthy of the name should be able to do it. Olds and Cadillac ran V-8's on 6 volts from 1949 to 54, IIRC. No, it's not a good idea. Cranking an engine with the compression ratio of the average small block V8 would put a lot of load on a 6V battery, unless you're willing to run one of the big batteries we used to use in banks of 4 on the big Diesel rigs. It definitely won't fit in the normal location for a battery on a stovebolt. You'll also be stuck with a relatively low-voltage point-type ignition system, because I can't think of anybody who makes a 6 volt HEI system. Bad idea!
