0 members (),
95
7
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 22 New Guy | | New Guy Joined: Aug 2004 Posts: 22 | What 6-volt distributor for for a chevy v-8.? Can a 12 volt starter be re-wound to make it a 6 volt? Thanks bob Fortner | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | none and no ... if you're going to a V8 in a 6 volt truck then you're also looking at changing to 12V - [and it's actually the coil that's 6 or 12V, the dist doesn't care]
might help to state a bit about what you're working with and what you want to end up with
Bill | | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | Yes, it's possible to rework a V-8 starter for 6 volts. Any good starter/alternator rebuilder worthy of the name should be able to do it. Olds and Cadillac ran V-8's on 6 volts from 1949 to 54, IIRC. No, it's not a good idea. Cranking an engine with the compression ratio of the average small block V8 would put a lot of load on a 6V battery, unless you're willing to run one of the big batteries we used to use in banks of 4 on the big Diesel rigs. It definitely won't fit in the normal location for a battery on a stovebolt. You'll also be stuck with a relatively low-voltage point-type ignition system, because I can't think of anybody who makes a 6 volt HEI system. Bad idea! Jerry
