5 members (Gdads51, TUTS 59, MickeyP, tclederman, 1 invisible), 75 guests, and 1 robot.
Topics128,049
Posts1,055,695
#652805 06/06/2010 7:12 PM
What is the average weight of a 1941-1947 2 or 3 Ton truck?
3B Offline
Hy ryansiki, of course it would depend on wheelbase, body or no body, cabover or conventional, but a good ballpark weight for a bare cab and chassis would be 3600 lbs., hope that helps.
ryansiki!
The spec booklet for 1946 shows a 'cab and chassis' as 4640 lbs.
With cab, platform and stock racks it's 5829 lbs.
Gives you some idea I hope.
Geo.
p.s. That's for a 160 in. wheelbase 2 ton
thanks guys
Hi,
I have a '53 6400 two ton dump bed with removable sides. The bed is 14' long and it weighs right around 7,000 lbs without the sides installed.
Hope this helps.
Phil
Plasticman
if you have a feed mill local to you run it over the scale and youll knw for sure. my trucks weigh in as follows
40 250 4,420 with side boards
51 350 "ashton" 10,000 lbs with no gear on it
51 6100 "murphy" 7,200 lbs
