| | | Forums66 Topics128,051 Posts1,055,710 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 4 New Guy | | New Guy Joined: Aug 2009 Posts: 4 | What is the average weight of a 1941-1947 2 or 3 Ton truck? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ryansiki, of course it would depend on wheelbase, body or no body, cabover or conventional, but a good ballpark weight for a bare cab and chassis would be 3600 lbs., hope that helps. | | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | ryansiki!
The spec booklet for 1946 shows a 'cab and chassis' as 4640 lbs.
With cab, platform and stock racks it's 5829 lbs.
Gives you some idea I hope.
Geo.
p.s. That's for a 160 in. wheelbase 2 ton
| | | | | Joined: Aug 2009 Posts: 4 New Guy | | New Guy Joined: Aug 2009 Posts: 4 | | | | | | Joined: Jul 2007 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 28 | Hi, I have a '53 6400 two ton dump bed with removable sides. The bed is 14' long and it weighs right around 7,000 lbs without the sides installed. Hope this helps. Phil Plasticman | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | if you have a feed mill local to you run it over the scale and youll knw for sure. my trucks weigh in as follows 40 250 4,420 with side boards 51 350 "ashton" 10,000 lbs with no gear on it 51 6100 "murphy" 7,200 lbs
