5 members (Hotrod Lincoln, Hanks custodian, Gdads51, Gray_Ghost, Maybellene), 80 guests, and 3 robots.
Topics128,066
Posts1,055,871
Members48,428
#653823 06/10/2010 8:08 PM
Howdy,
I'm reading some great advice on how to rebuild your whole door hinge, but has anyone come up with a good way to install the hinge springs while the hinge pin is already in place? I'm discovering this is pretty tricky.
Dave
Dave
GMCdp #653858 06/10/2010 9:36 PM
tclederman #653861 06/10/2010 10:06 PM
Thanks, Tim. I figured you were supposed to put everything together at once using the pin to leverage the springs, but I was wondering if anyone has a good way to get the springs into the slots when the hinge pin is already in stalled? My other upper hinge pin is just fine and I don't want to replace it.
Dave
GMCdp #653965 06/11/2010 11:15 AM
This was discussed last year and I believe the conclusion was that it's not possible.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #654058 06/11/2010 8:45 PM
That encouraging. Thanks, Woody!
If I'm successful I'll try to take pictures.
Dave
GMCdp #655208 06/16/2010 5:02 PM
Well I did it. It was a learning process, though. I built a complicated contraption using a bench vise, C-clamp, 7/8" socket, large end wrench, a wedge, welded spacer, and a shaped boss to conform to the spring when pressing it. This still wasn't successful.
In the end I took 2 hammers, one was a long wedge like cross pein body hammer, the other just a ball pein, lined 'er up and wack...went in like nothing.
Dave
GMCdp #655443 06/17/2010 12:11 PM
Got pictures?
Woody
Door Art Collection
Czechman #655477 06/17/2010 4:51 PM
In Ohio at the moment. Will try to get some posted next week.
I miss my stovebolt...
Dave
GMCdp #655594 06/18/2010 12:57 AM
Thanks, this question gets asked every now and then and it would be nice if that info were available. Like I said, last time this came up I don't believe anyone had good news.
Woody
Door Art Collection
Czechman #655797 06/18/2010 8:33 PM
I was able to do the spring install without taking the hinge apart but it involved the help of another person.
Rotate one leg of the spring into its hole on the inner hinge piece (the bar portion that bolts to the door). Place assembly on the ground and have someone stand on it so it doesn't move about. Take a pair of channel locks (thin head style is what I used) for compression and a thick awl for prying. Position channel locks, place awl in the slotted spring hole. Start squeezing and prying at the same time. A steady pace worked best for me. After figuring out the first spring I had the other three installed in less than ten minutes with minimal swearing. :-)
And sorry, no pictures of the event. Ran out of hands to operate the camera.
EDIT NOTE: Forgot to mention this was done on a late '49 3100.
In my world the sky is blue.
