6 members (Hotrod Lincoln, 2-Ton, Hugh63c10, Oswald, CuzzFuzz, 1955 1 Series), 61 guests, and 3 robots.
Topics128,089
Posts1,056,353
Members48,442
could anyone tell me the length of the u shaped rod that connects from the accelerator pump to the throttle linkage. it seams like i removed it and it was not in the project case when i went too put the kit in. in was not on the work bench nowhere to be seen again i will make one but i would like a approx size to start. after this i can try to start her for the first time in ten years
Riding in the Passing Lane
What model carb do you have. The 63-67 models used the Roch. model B. The 68 up used the monojet. I have some parts carbs for either one & can send you the link or measure it.
[email protected]
1972 Chevy c10 Cheyenne Super
it is the roch model b carb. if i could get the length i could make up one from here. i just cannot find it anywhere. or you could email me if i do not email you first. thank you
I'llget the demention tomorrow & e-mail it to you.
